[OpenLayers-Users] transitionEffect related performance issue in
firefox/ubuntu
Daniel Behr
daniel.behr at hzg.de
Wed May 9 07:42:36 EDT 2012
Hello,
maybe this is of interest to someone or someone even knows a workaround.
Its not primarily an OL issue, but some OL settings have an influence.
Since a while I see extremely bad performance zooming in/out in my OL
app. panning works fine, but zooming sometimes needs 5 seconds before
the first new tile shows up (and so on), which makes quick zoom/pan
actions impossible.
I'm using Ubuntu 10.04 32bit and this happens only in firefox. I'm also
quite sure that it got worse with every firefox release so that now with
FF12 it really became annoying.
on the same machine I have a FF 3.6.28, Chrome 18 and SeaMonkey 2.0
which are much faster (Chrome wins, of course).
I then checked out some colleagues' PCs/Browsers and found out that all
other combinations (openSUSE,Xubuntu,Windows) are reasonably fast,
except those also running ubuntu 10.04 32bit with firefox. ubuntu 10.04
64bit is fast, too.
The main reason is that firefox brings Xorg to 100% CPU usage when
zooming, which slows down the whole system. that seems to be a well
known problem, when you google 'ubuntu firefox xorg'. other (ubuntu)
systems seem to be affected, too.
I tried a few tweaks from the search results but nothing worked for me.
Then I saw that when I switch the baselayer in my app to standard OSM
everythings works just fine. One of the differences is the
transitionEffect=resize property on the layer. commenting that makes it
*alot* faster again.
I really like the transition effect, but I have no clue how many systems
might be affected and if I should rather not use it.
Are there other OL settings that may trigger browser rendering issues?
thanks
Daniel
Helmholtz-Zentrum Geesthacht
Zentrum für Material- und Küstenforschung GmbH
Max-Planck-Straße 1 I 21502 Geesthacht I Deutschland/Germany
Geschäftsführer/Board of Management: Prof. Dr. Wolfgang Kaysser, Dipl.-Ing. Michael Ganß
Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: MinDirig Wilfried Kraus
Amtsgericht Lübeck HRB 285 GE (Register Court)
Internet: http://www.hzg.de
