[OpenLayers-Users] Re: zoomed out view is wms and zoomed in is wfs
Paul Meems (Top-X)
p.meems at topx-group.nl
Fri May 18 00:48:39 PDT 2012
You will get two layers. One of them is grayed-out depending on the scale.
Using grouped layers you can avoid this, but that only works if all layers
are WMS
Paul
2012/5/17 sdunne <stephen.dunne at lisasoft.com>
> Paul Meems (Top-X) wrote
> > Create two layers, the WMS version and the WFS version and use maxscale
> > and
> > minscale to set when which layer should be visible.
> Thanks Paul, with this appraoch, in the layer selector, would this be
> viewed
> as 2 different layers.
> For example, when I reached a certian zoom level, the layer selector would
> visually change from the wms to the wfs of the same name, being selected?
> Or would only one layer be visible in the layer selector, and the
> functionality would be performed without the user knowing that the layer
> had
> changed ?
> http://osgeo-org.1560.n6.nabble.com/zoomed-out-view-is-wms-and-zoomed-in-is-wfs-tp4974909p4975241.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120518/783de79b/attachment.html
