[OpenLayers-Users] WMSFeatureInfo not working on Firefox on Ubuntu 12.04
Smaran Harihar smaran.harihar at gmail.com
Tue May 29 10:03:07 PDT 2012
Phil: Could this be the same issue as mine. Even i was not able to get it
done.
Danny: Of course I was not able to check on windows, but what is the error
that you are getting on your developer tool? Is it something related
to *XMLHttpRequest
not able to load*.
On Tue, May 29, 2012 at 9:23 AM, danny shevitz <shevitz at lanl.gov> wrote:
> Phil Scadden <p.scadden at ...> writes:
> > Got a proxy installed? You need it.
> > http://trac.osgeo.org/openlayers/wiki/FrequentlyAskedQuestions#ProxyHost
> > Notice: This email and any attachments are confidential. If received in
> error
> please destroy and
> > immediately notify us. Do not copy or disclose the contents.
> I am using nginx and uwsgi. I have proxy directives defined in the nginx
> configuration. You are correct that I am displaying layers from a Geoserver
> which is not on the server. However I am able to see WMS layers on the
> Geoserver
> just fine. It is only the WMSGetFeatureInfo that is failing. I presume
> WMSGetFeatureInfo uses a GET request under the hood. If so, my proxy is
> fine
> because otherwise, the WMS layer wouldn't display.
> In addition, and the real killer, is that hitting the same server from a
> Windows
> box, renders the map just fine and allows the clickable interaction I
> need. It
> only seems to be a problem of the Firefox client on Ubuntu.
> Again to reiterate,
> Ubuntu Firefox -> known working remote server fails
> Ubuntu Firefox -> same machine server fails
> Windows box Firefox -> know working remote server works
> Windows box Firefox -> same Ubuntu machine server two lines up works
> Any ideas?
> thanks,
> Danny
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120529/5f981957/attachment.html>
