[OpenLayers-Users] WMSFeatureInfo not working on Firefox on Ubuntu 12.04
Gery .
gamejihou at hotmail.com
Tue May 29 14:12:28 PDT 2012
it was actually my own pc, I added for example: http://123.456.789/gery.html in my html, and I was using in FF: http://localhost/gery.html, that's why it could see the map but after clicking the features but no response at all. Well I don't use geoserver, I use Mapserver which is much more simple for me, so no idea about geoserver. If you think it is the browser, update it, FF is in the 12 version now, I also noticed some problems with older versions of FF (3 i think) and my app, problem that didn't happen in FF 7 and above for instance.
HTH,
> To: openlayers-users at lists.osgeo.org
> From: shevitz at lanl.gov
> Date: Tue, 29 May 2012 21:04:08 +0000
> Subject: Re: [OpenLayers-Users] WMSFeatureInfo not working on Firefox on Ubuntu 12.04
> Gery . <gamejihou at ...> writes:
> > Hello Danny,I don't know if this will help you but I had a similar problem,
> ie. my map was unclickable. I pressed almost everthing in my keyboard but
> nothing, the thing never worked. After rechecking things, my mistake was that I
> assigned the ip in my html and was trying to get the map through localhost, it
> was quite silly the error but yes it happens sometimes. Perhaps something very
> obvious is actually your problem, and the code might be right.HTH,Gery
> Could you please be a little more specific? Everything in our application is
> specified in terms of relative paths. e.g. app.local/geoserver. Which ip are you
> referring to? I don't think we have any urls/ip's at all in our code, only in
> the nginx configuration. I grep'ed out code and we have no mention of localhost
> at all.
> e.g. the get feature control is created via
> control=new OpenLayers.Control.WMSGetFeatureInfo({url:'/geoserver/wms'...}
> Also was you problem consistent with having the same server provide a clickable
> map on another machine? The remote map works fine, it's the browser on the same
> machine as the server that's the problem. If it were a problem that I specified
> localhost somewhere, I would would expect a not working page on the remote
> machine, exactly the opposite of what I have.
> thanks,
> Danny
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120529/dae7b093/attachment.html>
