[OpenLayers-Users] WMSFeatureInfo not working on Firefox on Ubuntu 12.04
Gery . gamejihou at hotmail.com
Tue May 29 14:32:35 PDT 2012
probably your error is Apache, check here: http://ubuntuforums.org/showthread.php?t=833523
try in linux: sdiff -s /etc/hosts c:/system/win32/drivers/etc/hosts, what do you get? if you can click your map in windows, I think the problem is apache in ubuntu, also try assigning your ip address: www.whatismyipaddress.com
I've heard that people had problems in Ubuntu, not only with OL, but with other open source. If you can get Centos, you should go for it.
HTH,
> To: openlayers-users at lists.osgeo.org
> From: shevitz at lanl.gov
> Date: Tue, 29 May 2012 21:21:13 +0000
> Subject: Re: [OpenLayers-Users] WMSFeatureInfo not working on Firefox on	Ubuntu 12.04
> Gery . <gamejihou at ...> writes:
> > it was actually my own pc, I added for example: http://123.456.789/gery.html
> in my html, and I was using in FF: http://localhost/gery.html, that's why it
> could see the map but after clicking the features but no response at all. Well I
> don't use geoserver, I use Mapserver which is much more simple for me, so no
> idea about geoserver. If you think it is the browser, update it, FF is in the 12
> version now, I also noticed some problems with older versions of FF (3 i think)
> and my app, problem that didn't happen in FF 7 and above for instance.HTH,
> Thanks again for the response. I am using FF 12.0.
> On both machines, Ubuntu (same as the server machine) and Windows, I am
> referring to the website using a url "app.local" which is specified in
> /etc/hosts on Ubuntu
> and c:/system/win32/drivers/etc/hosts to 127.0.0.1
> Anything I am missing?
> thanks,
> Danny
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120529/5c103434/attachment.html>
