[OpenLayers-Users] WMSFeatureInfo not working on Firefox on Ubuntu 12.04
danny shevitz shevitz at lanl.gov
Tue May 29 14:57:09 PDT 2012
Gery . <gamejihou at ...> writes:
> probably your error is Apache, check here:
http://ubuntuforums.org/showthread.php?t=833523try in linux: sdiff -s /etc/hosts
c:/system/win32/drivers/etc/hosts, what do you get? if you can click your map in
windows, I think the problem is apache in ubuntu, also try assigning your ip
address: www.whatismyipaddress.comI've heard that people had problems in Ubuntu,
not only with OL, but with other open source. If you can get Centos, you should
go for it.HTH,
I'm not using Apache,
I'm using Nginx for my server.
D
