[OpenLayers-Users] offline tiles
Jochen Wagner
jj.wag at gmx.de
Thu Jul 11 01:51:44 PDT 2013
I try to use downloaded TMS tiles offline without a Server.
My tiles are saved local on my Windows machine (no tileserver!):
C:\inetpub\wwwroot\test\tiles\1.0.0\test1
C:\inetpub\wwwroot is the root dir of my local webserver.
If I use folowing configuration the client shows the tiles fine (because the tiles come via http):
var test_xyz = new OpenLayers.Layer.TMS( "test_xyz",
"http://localhost/test/tiles/",
layername: 'test1',
type: "jpg",
isBaseLayer:true,
transitionEffect:'resize',
resolutions:[529.16666666670005270134,396.87500000000000000000,264.58333333330000414207],
units: projUnits,
projection: mapProj,
sphericalMercator: false
if I change the URL to the file it doesn't work.
"file:///C:/inetpub/wwwroot/test/tiles/",
layername: 'test1',
type: "jpg",
isBaseLayer:true,
units: projUnits,
In Firebug I see that there comes no request.
If I try to use a OpenLayers.Layer.XYZ Object I have the same problem.
Later I want to use the tiles on an android device.
Any idea?
Thanks
Jo
