[OpenLayers-Users] offline tiles
Jürgen Dankoweit
Juergen.Dankoweit at T-Online.de
Thu Jul 11 08:22:05 PDT 2013
Hi Jochen,
Am 11.07.2013 10:51, schrieb Jochen Wagner:
> Hi,
> I try to use downloaded TMS tiles offline without a Server.
> My tiles are saved local on my Windows machine (no tileserver!):
> C:\inetpub\wwwroot\test\tiles\1.0.0\test1
> C:\inetpub\wwwroot is the root dir of my local webserver.
> If I use folowing configuration the client shows the tiles fine (because the tiles come via http):
> var test_xyz = new OpenLayers.Layer.TMS( "test_xyz",
> "http://localhost/test/tiles/",
> layername: 'test1',
> type: "jpg",
> isBaseLayer:true,
> transitionEffect:'resize',
> resolutions:[529.16666666670005270134,396.87500000000000000000,264.58333333330000414207],
> units: projUnits,
> projection: mapProj,
> sphericalMercator: false
> if I change the URL to the file it doesn't work.
> "file:///C:/inetpub/wwwroot/test/tiles/",
> layername: 'test1',
> type: "jpg",
> isBaseLayer:true,
> units: projUnits,
> In Firebug I see that there comes no request.
> If I try to use a OpenLayers.Layer.XYZ Object I have the same problem.
> Later I want to use the tiles on an android device.
I'm trying to create an application for my Nokia N900 that uses offline
maps too. I found the following solution:
var tms = new OpenLayers.Layer.TMS( "TMS", "", {
type: 'png',
getURL: my_getTileURL, // <------------+
alpha: true, // |
isBaseLayer: true // |
function my_getTileURL(bounds) { // <---+
var res = this.map.getResolution();
var x = Math.round((bounds.left - this.maxExtent.left) / (res *
this.tileSize.w));
var y = Math.round((bounds.bottom - this.tileOrigin.lat) / (res *
this.tileSize.h));
var z = this.map.getZoom();
if (mapBounds.intersectsBounds( bounds ) && z >= mapMinZoom && z <=
mapMaxZoom ) {
console.log( this.url + z + "/" + x + "/" + y + "." + this.type);
return 'file:///<tiles_directory>/'+this.url + z + "/" + x + "/" + y +
"." + this.type;
} else {
return "empty_image.png";
I hope this helps.
Best regards
Jürgen
Meine stets unfertige Homepage: www.dankoweit.de
