[OpenLayers-Users] GIS newbie question: drawing lines projected as arcs on the earth
Phil Scadden
p.scadden at gns.cri.nz
Mon Jul 22 16:25:31 PDT 2013
> If I have a base map of the earth, and want to draw a vector of a flight path
> for example from LA to NYC, does OpenLayers have a way to draw this path as
> a 'curved' path to match the arc shape of the path vs a straight linestring
> path ? Or would I need to calculate this myself client side and hand build a
> linestring with a bunch of interpolated points ?
A great-circle path is not a simple vector, so as far as I know, you
will have to calculate the curve yourself. I am not aware of any inbuilt
tools within OL that will do it for you (and if it did, the calculation
is client-side).
Try here for some js code on doing it.
http://trac.osgeo.org/openlayers/wiki/GreatCircleAlgorithms
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
