[OpenLayers-Users] WPS Execute request - the ResponseForm
Bart van den Eijnden
bartvde at boundlessgeo.com
Wed Aug 27 08:55:21 PDT 2014
According to the schema what OpenLayers produces is fine.
But I’m not sure if there is anything in the WPS document that mandates what Zoo expects.
Best regards,
Bart
Front End Software Engineer | Boundless
1-877-673-6436
@boundlessgeo
On 27 Aug 2014, at 17:38, Alexandre Dubé <adube at mapgears.com> wrote:
> Hi list,
> I have questions about the XML produced by the WPSExecute format. I already asked the same questions on the Zoo mailing list since it's regarding a difference ResponseForm node their example page use from the one produced by OpenLayers WPSExecute format: http://lists.osgeo.org/pipermail/zoo-discuss/2014-August/001160.html
> What Zoo expect:
> <wps:ResponseForm>
> <wps:RawDataOutput>
> <wps:Output mimeType="application/json">
> <ows:Identifier>Result</ows:Identifier>
> </wps:Output>
> </wps:RawDataOutput>
> </wps:ResponseForm>
> What OpenLayers WPSExecute format outputs:
> <wps:ResponseForm>
> <wps:RawDataOutput>
> <ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">Result</ows:Identifier>
> </wps:ResponseForm>
> Unless the extra "Output" node gets added, Zoo throws an error: 'Wrong RawDataOutput parameter, unable to fetch any result for the name your provided : "unknownIdentifier".' So, my question is more a OGC:WPS oriented one: should openlayers output this extra node or not ? An expert reading schemas should be able to tell more (http://schemas.opengis.net/wps/1.0.0/wpsExecute_request.xsd, I get confused trying to understand it).
> Thanks a lot,
> Alexandre Dubé
> T: +1 418-696-5056 #203
> http://www.mapgears.com/
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140827/23096d09/attachment.html>
