[osgeo4w-dev] gdaI-dev: ippj-5.3.dll not found
Klokan Petr Přidal klokan at klokan.cz
Fri Nov 14 13:01:00 EST 2008
Hi Frank,
> Is there any chance these folks might have installed the libjpeg-ipp
> package?
I think they selected only the gdal-dev package and other dependent
packages were installed automatically.
Isn't there some kind of detection for selecting IPP version of
libjpeg as dependency?
What should they try to run to help you to localize the problem?
I am just man in the middle as I did not succeed to reproduce the
error on my computer unfortunately.
> The intention is that this optional package is the only one that should
> depend on having the IPP primatives preinstalled.  The default libjpeg
> package should not depend on IPP.
Is not it possible that there is dependency also somewhere else?
> I would suggest you file a ticket on this issue where we can follow up
> on the details.
OK. Further discussion will continue as OSGeo4W Ticket #27:
http://trac.osgeo.org/osgeo4w/ticket/27
Best regards
Petr
More information about the osgeo4w-dev mailing list
