[osgeo4w-dev] Problems re-installing on WinXP 64
Wed Jan 14 14:40:13 EST 2009
Lucena, Ivan wrote:
> That means to me two things:
> - GDAL15 was build with OGDI dependence.
> - The installer is failing to auto select the OGDI package.
> I run again and install OGDI then the problem is zlib_osgeo.dll
Ivan,
Is there any chance you are using an old setup executable?  This sounds like
a bug we used to have but was fixed (perhaps 4-6 months ago).
Best regards,
More information about the osgeo4w-dev mailing list
