Re: [osgeo4w-dev] Problems re-installing on WinXP 64
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Jan 14 15:03:59 EST 2009
Frank,
I could not find any difference between the osgeo4w-setup.exe that I am using and the one on http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe. They both have the same size 387K.
C:\Documents and Settings\ilucena>fc "C:\Documents and Settings\ilucena\My Documents\Downloads\osgeo4w-
setup.exe" E:\temp\osgeo4w-setup.exe
Comparing files C:\DOCUMENTS AND SETTINGS\ILUCENA\MY DOCUMENTS\DOWNLOADS\osgeo4w-setup.exe and
E:\TEMP\OSGEO4W-SETUP.EXE
FC: no differences encountered
I right click and opened the file properties/summary and there is no version information either.
Thanks anyway,
Ivan
>  -------Original Message-------
>  From: Frank Warmerdam <warmerdam at pobox.com>
>  Subject: Re: [osgeo4w-dev] Problems re-installing on WinXP 64
>  Sent: Jan 14 '09 19:40
>  Lucena, Ivan wrote:
>  > That means to me two things:
>  > - GDAL15 was build with OGDI dependence.
>  > - The installer is failing to auto select the OGDI package.
>  > I run again and install OGDI then the problem is zlib_osgeo.dll
>  Ivan,
>  Is there any chance you are using an old setup executable?  This sounds like
>  a bug we used to have but was fixed (perhaps 4-6 months ago).
>  Best regards,
>  I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>  light and sound - activate the windows | http://pobox.com/~warmerdam
>  and watch the world go round - Rush    | Geospatial Programmer for Rent
More information about the osgeo4w-dev mailing list
