[osgeo4w-dev] Re: [osgeo4w] #32: the template for batch files
should have a quoted path, else CALL fails
trac_osgeo4w at osgeo.org
Thu Jan 22 15:04:27 EST 2009
#32: the template for batch files should have a quoted path, else CALL fails
Reporter: maphew | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone:
Component: Installer | Version:
Resolution: fixed | Keywords:
Comment (by maphew):
better solution (also documented in packaging instructions):
@echo off
SET OSGEO4W_ROOT=@osgeo4w@
call %OSGEO4W_ROOT%\bin\o4w_env.bat
start /B %OSGEO4W_ROOT%\bin\foo.exe %*
@echo on
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/32#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
