[osgeo4w-dev] SVN error message
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun Feb 14 22:45:11 EST 2010
I am not sure if anyone else is getting this error, but when I commit
changes to /setup I get the following error (below). The commit occurs,
but some actions to be performed after the commit seem to be a problem:
Transmitting file data .
Committed revision 1141.
Warning: post-commit hook failed (exit code 1) with output:
svnlook: Expected FS format '2'; found format '3'
File "/var/www/svn/hookscripts/trac-post-commit-hook", line 207, in ?
CommitHook()
File "/var/www/svn/hookscripts/trac-post-commit-hook", line 142, in
__init__
repos = self.env.get_repository() # will do a `sync` if needed
File "/usr/lib/python2.3/site-packages/trac/env.py", line 195, in
get_reposito
ry
return RepositoryManager(self).get_repository(authname)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py",
line 91, i
n get_repository
raise TracError('Unsupported version control system "%s"'
trac.core.TracError: Unsupported version control system "svn"
-jeff
More information about the osgeo4w-dev
