[osgeo4w-dev] SVN error message
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Feb 17 15:27:37 EST 2010
I get this error when I commit from my work computer (Win7x64 and
TortoiseSVN 1.6.7, Build 18415 - 64 Bit , 2010/01/22 17:55:06) but not
from home (WinXP, QSVN).
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Jeff McKenna wrote:
> I am not sure if anyone else is getting this error, but when I commit
> changes to /setup I get the following error (below). The commit occurs,
> but some actions to be performed after the commit seem to be a problem:
> Transmitting file data .
> Committed revision 1141.
> Warning: post-commit hook failed (exit code 1) with output:
> svnlook: Expected FS format '2'; found format '3'
> Traceback (most recent call last):
> File "/var/www/svn/hookscripts/trac-post-commit-hook", line 207, in ?
> CommitHook()
> File "/var/www/svn/hookscripts/trac-post-commit-hook", line 142, in
> __init__
> repos = self.env.get_repository() # will do a `sync` if needed
> File "/usr/lib/python2.3/site-packages/trac/env.py", line 195, in
> get_reposito
> ry
> return RepositoryManager(self).get_repository(authname)
> File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py",
> line 91, i
> n get_repository
> raise TracError('Unsupported version control system "%s"'
> trac.core.TracError: Unsupported version control system "svn"
> -jeff
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
