[osgeo4w-dev] Wrong Apache port number in doc
Yves Jacolin yves.jacolin at camptocamp.com
Fri Feb 19 10:31:46 EST 2010
Hello,
I changed this line in the main page [1]
>Web applications will be available at http://localhost:8080/
to
>Web applications will be available at http://localhost/
as apache works on the 80 default port.
Furthermore, for my installaion I have to choose "Apache install" in the menu
before to run "Apache start". Is it the right way to use Apache? If so I think
it needs some documentation somewhere ;)
Thanks,
Y.
[1] http://trac.osgeo.org/osgeo4w/wiki/WikiStart
Yves Jacolin
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 26 57 98
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
More information about the osgeo4w-dev mailing list
