[osgeo4w-dev] python modules
Matt Wilkie
matt.wilkie at gov.yk.ca
Thu May 19 18:38:31 EDT 2011
Hi John,
There isn't yet an integrated method for installing python extras which
aren't part of the osgeo4w package system. A route that does work with a
bit extra twiddling is to register the o4w python as the system default
python[1], after which you can use the standard installers. If that
doesn't work or isn't acceptable you'll have to manually put it in
python's site-packages directory (there may be some more steps than
that. I'm not familiar with pygments).
[1] http://trac.osgeo.org/osgeo4w/ticket/114 - doesn't work on 64bit
systems, but if you study the .reg files one directory up you can see
how to make your own reg file to import manually.
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 19/05/2011 11:14 AM, John Callahan wrote:
> Quick question regarding OSGeo4W. What is the best/preferred way to
> install python modules within OSGeo4W? For example, I use QGIS 1.7dev
> and tried to install the QGIS plugin "Fast SQL Layer." It could not
> install and returned that python module "pygments" must be installed.
> Doe sOSGeo4W come with a python module installer, or something
> similar? Thanks.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey
> University of Delaware
> URL: http://www.dgs.udel.edu
More information about the osgeo4w-dev
