[osgeo4w-dev] [osgeo4w] #305: sqlite/spatialite: "sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll"
trac_osgeo4w at osgeo.org
Sat Oct 27 14:32:32 PDT 2012
"sqlite3.dll"
Reporter: hellik | Owner: brushtyler
Type: defect | Status: new
Priority: critical | Component: Package
Version: 1.0 | Keywords: sqlite,spatialite
Comment(by hellik):
Replying to [comment:19 brushtyler]:
> Replying to [comment:18 hellik]:
> > can you try '''DISABLE_GEOMETRY_CALLBACKS''' in '''spatialite'''?
> yes, I can (and I'm doing it), but I guess this won't fix the problem.
> BTW, in SpatiaLite 3.0.1 (the version shipped with OSGeo4W) the name of
the flag is '''OMIT_GEOCALLBACKS''', probably it was changed to
DISABLE_GEOMETRY_CALLBACKS in the last splite version.
I've just done a ./configure --help in the libspatialite-3.0.1-source
within the osgeo4w-msys:
`configure' configures libspatialite 3.0.1 to adapt to many kinds of
systems.
--enable-geocallbacks enables geometry callbacks [default=yes]
maybe time to ask Sandro as developer of spatialite to avoid confusion
(I'm a little bit)?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/305#comment:21>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
