[osgeo4w-dev] Updating package dependencies
Jürgen E. Fischer jef at norbit.de
Mon Jul 8 03:05:28 PDT 2013
Hi Julien,
On Mon, 08. Jul 2013 at 11:26:00 +0200, Julien Malik wrote:
> - simply update the setup.hint : nothing changes in the installer, the
>   new dependency is not automatically checked when doing Reinstall nor
>   Remove/Install again
The installer doesn't evaluate the setup.hints directly
> - run the osgeo4w-regen.sh : blank page appear, and same result
That should have helped to rebuild the setup.ini from the setup.hints.
But there shouldn't have been a blank page.
Apparently steve accidentally changed the ownership of the file, when trying to
add a license field to the ini - that caused it - fixed.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to QGIS                                IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
