[osgeo4w-dev] Updating package dependencies
Julien Malik
julien.malik at c-s.fr
Mon Jul 8 03:21:32 PDT 2013
Thank you Jürgen.
On 07/08/2013 12:05 PM, Jürgen E. Fischer wrote:
> Hi Julien,
> On Mon, 08. Jul 2013 at 11:26:00 +0200, Julien Malik wrote:
>> - simply update the setup.hint : nothing changes in the installer, the
>> new dependency is not automatically checked when doing Reinstall nor
>> Remove/Install again
> The installer doesn't evaluate the setup.hints directly
>> - run the osgeo4w-regen.sh : blank page appear, and same result
> That should have helped to rebuild the setup.ini from the setup.hints.
> But there shouldn't have been a blank page.
> Apparently steve accidentally changed the ownership of the file, when trying to
> add a license field to the ini - that caused it - fixed.
> Jürgen
More information about the osgeo4w-dev
