[osgeo4w-dev] GSoC - OSGeo4W 2013 Weekly reports #1
Lord Flaubert Steve Ataucuri Cruz
lord.ataucuri at ucsp.edu.pe
Fri Jun 21 09:13:34 PDT 2013
Hi All
I am Steve Ataucuri and my GsoC project is "Extend OSGeo4W Installer"
These are the tasks that I've been doing during this week:
Work done in week 17-21 June
* What Do I did this week?
1. I understood the structure of OSGeo4W Installer
2. I also setuped a local virtual machine with Windows envirotment
and all the tools needed in order to getting a build of setup.exe
3. I fixed some errors of setup.exe and I sent my changes to svn server:
- I included a hack implementation of _fstati64() because at
linking time presents some problems with Cygwin/Mingw libraries.[1]
- I fixed the linking to res.o object when make program try to
build setup.exe it presents some problems, I solved removing the
codepage in res_* files to use UTF-8 enconding for multilanguage
support [2]
- I updated the iniparse.yy file, it has some incompatible changes
with the new version of Automake 1.2 and YACC & LEX support.[3]
- I removed some obsolete macros in configure.in file, too it was
moved to newer configure.ac [4]
- I fixed the static library path of libbz2.a and libz.a in
Makefile.am file [5]
* What will I be working the next week?
- Next week I need to prepare the new windows dialogs for new
version of installer.
- I will update the wiki of the project to build the new setup.
* Did I meet with any stumbling blocks?
Definitely yes, some problems with the installation of Installer but
are already solved, many times I needed to read a lot before changing
a line of the code of setup installer.
[1] https://trac.osgeo.org/osgeo4w/changeset/1207
[2] https://trac.osgeo.org/osgeo4w/changeset/1208
[3] https://trac.osgeo.org/osgeo4w/changeset/1209
[4] https://trac.osgeo.org/osgeo4w/changeset/1210
[5] https://trac.osgeo.org/osgeo4w/changeset/1211
Comments and Suggestions are welcome
Best regards
Steve
Steve Ataucuri Cruz
School of Computer Science,
San Pablo Catholic University - Arequipa, Peru (http://www.ucsp.edu.pe),
Screen Names :
stonescenter at hotmail.com (Windows Live Messenger)
stonescenter at gmail.com (Google talk)
stonescenter at yahoo.com (Yahoo Messenger)
stonescenter (Skype)
+51.972529201 (Mobile)
More information about the osgeo4w-dev
