[osgeo4w-dev] matplotlib update to 1.2.1
Jürgen E. Fischer jef at norbit.de
Tue Jun 25 05:33:53 PDT 2013
Hi Alexander,
On Tue, 25. Jun 2013 at 12:09:30 +0300, Alexander Bruy wrote:
> I updated matplotlib package to 1.2.1. Main reason is that new version
> works fine with both PyQt API's v1 and v2, while old one don't work with
> PyQt API v2.
Thanks.
> osgeo4w-setup.exe -t http://download.osgeo.org/osgeo4w/setup_test.ini
BTW -t is enough.  And the setup package comes with a setup_test.bat, which
also installs from the setup_test.bat.
> I'll promote package in evening if there are no objections.
A nightly build (GRASS or QGIS, whatever comes first) will do that anyway.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
