[osgeo4w-dev] Ship improved OGR-SOSI driver with OSGeo4w
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Oct 24 00:50:28 PDT 2013
Dear OSGeo4W-dev/packagers
The last few days, the build process for the GDAL/OGR SOSI-driver as well as for the underlying OpenFYBA-library has been reasonably improved.
(SOSI is a topological vector-data format-standard used by the Norwegian Mapping Authoritiy: Kartverket.)
Now, MS Visual Studio project files are available together with the source-code for the OpenFYBA-lib (with license-terms according to GDALs license, https://github.com/kartverket/fyba).
Furthermore the SOSI-driver can be built as a GDAL-plugin (http://trac.osgeo.org/gdal/ticket/3638) and build-hints can be found at: http://trac.osgeo.org/gdal/wiki/SOSI.
How should we proceed if we want to get the driver into OSGeo4W?
We are thankfull for any hints!
Best regards
Stefan
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20131024/a47e3fc1/attachment.html>
More information about the osgeo4w-dev
