[osgeo4w-dev] null grid missing from PROJ 5 package
Helmut Kudrnovsky hellik at web.de
Tue Apr 17 12:16:41 PDT 2018
Kristian Evers-2 wrote
> Hi,
> It would seem like the null grid is not being installed properly for the
> proj-5.0.1RC1-1 package. The file is not present in OSGeo4W64\share\proj
> when 5.0.1 is installed. It is installed correctly for version 4.9.3. I
> wonder if this is simply a blunder in the OSGeo4W package or if something
> has changed from version 4 to 5 that has caused this file to not be
> installed correctly by the build system. Any insights as to which it may
> be?
> On a related note, the final version of 5.0.1 has been out for a couple of
> weeks now. Additionally proj-datumgrids 1.7 has been out since March 1st.
> Time for an update? I am happy to help with this if it is too much work to
> keep these packages up to date. This is something I rely on and am happy
> to spend the necessary time on. I may need a bit of help to get started
> though.
> /Kristian
good starting points are:
Installed Directory Layout:
https://trac.osgeo.org/osgeo4w/wiki/DirectoryLayout
Packaging Instructions:
https://trac.osgeo.org/osgeo4w/wiki/PackagingInstructions
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/osgeo4w-dev-OSGeo-Win32-Installer-List-f3765018.html
More information about the osgeo4w-dev mailing list
