[OSGeoJapan-discuss] Integration of Japanese GIS formats into mainline GDAL ?
Ko Nagase
nagase @ georepublic.co.jp
2015年 7月 20日 (月) 06:50:35 PDT
Hi Even,
CC: Hiroo-san, Yamate-san, list
Excuse me for cutting in this topic.
I am neither the developer nor the player, but I tried mext_gdal
test version (gdal110_test.zip) at last weekend and probably I understood
some data related part, so I mention some of your question about datas.
(But, if someone find my mistake, please point it out here...)
2015-05-01 18:59 GMT+09:00 Even Rouault <even.rouault @ spatialys.com>:
> I tried the FGD ogr driver on the file
> https://github.com/msherry/PyXB-1.1.4/blob/master/examples/unicode_jp/data/shift_jis/FG-
> GML-13-RailCL25000-20080331-0001.xml
> (found by googling FG-GML)
> It is not recognized by the driver. Looking more closely, the driver seems to
> expect a <GI> element that isn't found in that file. It appears that there are
> several versions of FGD GML, right ? The above file is apparently v3 (since
> there's a v3 schema next to it). Perhaps the driver is v4 (or a previous
> version) ? I tried to remove the test for the presence of <GI> but it crashes
> later during parsing of dates, apparently not liking the <gml:timePosition>
> element within <lfSpanFr>
There are 2 format types (DLD / GML), 2 recent versions(v3 / v4)
and 2 (or more) data types (5/10m mesh DEM / General vector data .etc)
in FGD data,
and current mext_gdal test version seems to support the following pair.
1. FGD driver: DLD v3 (5/10m mesh DEM)
2. FG-GML driver: GML v3 (5/10m mesh DEM)
3. FGD driver: DLD v3 (General vector data)
Above link which you found use GML v3, but it is not 5/10m mesh DEM,
so you couldn't convert it.
> I found this project : http://mizutuu.github.io/jpgisgmlv4togml-converter/ /
> https://github.com/mizutuu/jpgisgmlv4togml-converter
> It includes the schema for FG-GML v4 and I can't see any reference to the <GI>
> element in it either.
> With some trickery related to encoding conversion, I managed to use that
> project to produce a standard GML file that the OGR GML driver handles well :
> cat FG-GML-13-RailCL25000-20080331-0001.xml | iconv --from-code=shift-jis --
> to-code=utf-8 | sed "s/Shift_JIS/UTF-8/" | python jpgisgml2gml.py > out.gml
And above GML v4 is not supported (both of 5/10m mesh DEM and
General vector data) by current mext_gdal for now.
> I've also found this site http://nlftp.mlit.go.jp/ksj-e/ and downloaded a few
> datasets. Those I tried are not handled by the OGR FGD driver. Some of them
> look like GML with a particular application schema. They are unfortunately not
> standard enough for the OGR GML driver to understand them out of the box,
> although I believe it could be tweaked to parse them. Their header look like:
> <ksj:Dataset gml:id="A09Dataset"
> xmlns:ksj="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app"
> xmlns:gml="http://www.opengis.net/gml/3.2"
> xmlns:xlink="http://www.w3.org/1999/xlink" xm
> lns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app KsjAppSchema-
> A09-v3_1.xsd">
> There's a shapefile next to them, with apparently same content.
And about above MLIT NLNI(National Land Numerical Information) data,
it is not FGD data...
> So it appears there's a variety of GML-like formats ;-)
Yes, sure...
If you want to use mext_gdal test data, I just uploaded example dummy data
to the following repository. So, please try to use those files.
https://github.com/sanak/dev-notes/tree/master/datas/fgd
(The dummy data location is near by Japan Wakayama prefecture,
but on the pacific ocean.)
Regards,
>> Hi Even,
>> I talk to Yamate-san who has been working on those three drivers. He
>> explained that each driver has little bit different copy right background
>> he need to resolve before he can merge them to the main.
>> The first one, FGD driver, which he wrote for a project and he does not
>> have control on its copy right. So, he would like to leave it at this
>> moment.
>> For the second one, FG-GML driver, he wrote it and he owns its copy right
>> at this moment. But he said he can release with the licence you suggested.
>> The last one, FGD ogr driver, which he also wrote and it is highly possible
>> he can release it under the MIT licence. But he need to make sure his
>> client can agree on this. So, he said he will contact to his client.
>> So, the last two drivers can be merge into the main GDAL driver. It is
>> little bit confusing background but I am sure we can sort these out.
>> I will let you know when he is ready to work with you.
>> Thanks!
>> Hiroo
>> On Thu, Apr 30, 2015 at 2:26 PM, Hiroo Imaki <hiroo @ angeli.org> wrote:
>> > Hi Even,
>> > I am not the developer but he and I working at a same company. If he can
>> > agree on the license and release his efforts, that would be wonderful for
>> > all Japanese data uses.
>> > He hesitates writing his message in English. So, I can be a translator
>> > between you guys. I hope no lost in translation!
>> > I will get back to you once I hear from him.
>> > Hiroo
>> > On Thu, Apr 30, 2015 at 10:45 AM, Even Rouault
>> > > wrote:
>> >> Hi,
>> >> Sorry for writing in English, but I don't unfortunately speak Japanese.
>> >> I'm one of the GDAL developers.
>> >> I've noticed that there are "un-official" versions of GDAL floating
>> >> around, with
>> >> a few drivers for new Japanese-specific formats. I was wondering if
>> >> there was a
>> >> reason to keep them outside of the official GDAL tree ? Integrating them
>> >> into
>> >> mainline GDAL would probably make life of Japanese users easier. GDAL
>> >> has already support for a lof of national specific formats, mainly in
>> >> Europe and
>> >> North America. Would be cool for Asia to join in ;-)
>> >> In a recent discussion thread, the following link is mentionned:
>> >> https://www.dropbox.com/s/4oyhncknavdk2if/gdal110_test.zip
>> >> I can see that it contains 2 new GDAL drivers ( FGD: Japanese
>> >> Fundamental Geographic Data (.xml) & FG-GML : Japanese Fundamental
>> >> Geographic Data GML(.xml) ) and one OGR driver (FGD).
>> >> Unfortunatelly there's no author or copyright information in the header
>> >> of the
>> >> corresponding source files. Would their author(s) be willing to release
>> >> them
>> >> under the X/MIT license and contribute them to the mainline GDAL project
>> >> ? Perhaps some test files to write minimalistic regressions tests would
>> >> be useful.
>> >> Let me know if I can be useful for anything. I can also help for writing
>> >> new
>> >> drivers if needed.
>> >> Best regards,
>> >> Even
>> >> Spatialys - Geospatial professional services
>> >> http://www.spatialys.com
>> >> _______________________________________________
>> >> OSGeoJapan-discuss mailing list
>> >> OSGeoJapan-discuss @ lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/osgeojapan-discuss
>> > Hiroo Imaki
>> > Pacific Spatial Solutions, LLC
>> > 1523 Chatham Colony Ct.
>> > Reston, VA 20190
>> > hiroo.imaki @ pacificspatial.com
>> > http://www.pacificspatial.com
>> > http://www.geopacific.org (GIS info site)
>> > hiroo @ angeli.org (private)
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase @ georepublic.co.jp
web: http://georepublic.co.jp
OSGeoJapan-discuss メーリングリストの案内
