[pgrouting-dev] [pgr_2.0] Just checked in code to eliminate GAUL
Dave Potts
dave.potts at pinan.co.uk
Fri Apr 5 06:02:55 PDT 2013
On 05/04/13 02:35, Stephen Woodbridge wrote:
Hi Stephen,
Can you drop me a line when you have fiinshed all the changes your going
to make, I like to try and get the ksp code up to the same release
stadnard.
Dave.
> Hi All,
> I have just checked in code into sew-devel-2_0 branch that eliminates
> the GAUL dependency and replaces the TSP solver with a simple C
> routine. I rewrote the TSP lib code to use the existing GAUL API and
> to use the postgresql memory management and added two test cases. I
> have build and tested on Win32-pg92 and Linux-pg84 with no problems.
> Daniel - Thanks for the feedback on TSP, I will look at it and see
> what I can do with your suggestions.
> The current code assumes a loop, ie: the start is also the end point.
> Other than that is should work as before.
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
