[pgrouting-dev] [pgr_2.0] Just checked in code to eliminate GAUL
Daniel Kastl
daniel at georepublic.de
Sat Apr 6 20:01:08 PDT 2013
Regina and Leo!
Thanks a lot for providing automated Windows builds!
A lot of people will appreciate a lot ... and for me this is a big headache
less ;-)
Daniel
On Sun, Apr 7, 2013 at 11:41 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Just a heads up. We plan to distribute pgRouting binaries with PostGIS
> builds moving forward. Steve has been helping us a lot with that effort as
> you can see.
> We'll also be setting up the PostGIS windows build bot in the next couple
> of weeks to autocompile/regress test whenever changes in the pgRouting code
> base.
> We have the pgRouting32 build up:
> http://winnie.postgis.net/download/windows/pg92/buildbot/
> Having some issue rebuilding the 64-bit, which we'll write up in a
> separate post.
> Thanks,
> Regina and Leo
> http://www.postgis.us
> http://postgis.net
> *From:* pgrouting-dev-bounces at lists.osgeo.org [mailto:
> pgrouting-dev-bounces at lists.osgeo.org] *On Behalf Of *Pieter du Plooy
> *Sent:* Saturday, April 06, 2013 3:16 AM
> *To:* pgRouting developers mailing list
> *Subject:* Re: [pgrouting-dev] [pgr_2.0] Just checked in code to
> eliminate GAUL
> Thanx Steve
> Do you perhaps have prebuilt binaries? (64 and 32 bit)?
> I will build during this week, just need to get my DEV machine up and
> running.
> On Sat, Apr 6, 2013 at 2:38 AM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> I built this based on the postgis mingw32 and ming64 build
>> environments. But if you pull my branch there is a tools directory at the
>> top level that has some scripts (more as doc then a runnable script) called:
>> makedependanciesw64.sh - how to build the dependencies
>> makepgroutingw32.sh - how to build under ming32
>> makepgroutingw64.sh - how to build under ming64
>> I say to look at these as docs not as scripts because they have a lot of
>> assumptions about directory structures and such.
>> There are also a couple of patch files in the tools directory also. With
>> my latest checking you do not need to build the GAUL dependency anymore.
>> -Steve
>> On 4/5/2013 1:09 AM, Pieter du Plooy wrote:
>> Steve
>> Is the windows build instructions the same as what I did last year for
>> the build that I made? (mingw?)
>> Pieter
>> On Fri, Apr 5, 2013 at 3:35 AM, Stephen Woodbridge <
>>> Hi All,
>>> I have just checked in code into sew-devel-2_0 branch that eliminates
>>> the GAUL dependency and replaces the TSP solver with a simple C routine. I
>>> rewrote the TSP lib code to use the existing GAUL API and to use the
>>> postgresql memory management and added two test cases. I have build and
>>> tested on Win32-pg92 and Linux-pg84 with no problems.
>>> Daniel - Thanks for the feedback on TSP, I will look at it and see what
>>> I can do with your suggestions.
>>> The current code assumes a loop, ie: the start is also the end point.
>>> Other than that is should work as before.
>>> -Steve
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130407/e384c4d2/attachment-0001.html>
More information about the pgrouting-dev
