[pgrouting-dev] Boost Versions???
Dave Potts
dave.potts at pinan.co.uk
Sat Mar 9 05:52:12 PST 2013
On 09/03/13 05:31, Daniel Kastl wrote:
On Ubuntu 12.04 I used CGAL-4.1, gaul 0.1850 libboost-random 1.48 with
postgres 9.1
Everything seem to work, but I have no way to prove it, other that the
fact that it did not break when I tested it.
D.
> Hi Steve,
> This is the "history" of libboost-dev on Ubuntu:
> http://packages.ubuntu.com/search?keywords=libboost-dev
> If newer versions of boost provide better functionality, then I
> wouldn't try to care too much about elder versions.
> For example your comment on this ticket:
> https://github.com/pgRouting/pgrouting/issues/34#issuecomment-3052852
> There were always issues with changing paths from version to version
> like here: https://github.com/pgRouting/pgrouting/issues/77
> So I would say it works with any version when you adjust a path here
> and there.
> Daniel
> On Sat, Mar 9, 2013 at 1:59 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> Hi Daniel, anyone?
> Do you know what Boost versions pgRouting works with?
> I running an ancient 1.34 on one system.
> I think I have run 1.41 on another system.
> I need to get a version for Win64 but I have no idea if some work
> and some don't from a pgRouting point of view.
> Thoughts?
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130309/311a5b74/attachment.html>
More information about the pgrouting-dev
