[pgrouting-dev] Problems linking on mingw64 between boost, cgal and threads
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 11 21:42:53 PDT 2013
Hi all,
I'm stuck at the moment trying to link the pgrouting driving directions
module using mingw 64 bit. See the issues below. So if anyone has any
thoughts on this it would be appreciated. I will check the current state
of the files into my branch in the morning here (GMT-5) if you are setup
to reproduce this. It is too late to do it with a clear head tonight.
I'll also move it back to Linux and try again there as I have changed a
lot of files.
Thanks,
-Steve
I have followed Sanak's directions from:
https://github.com/sanak/pgrouting4w/blob/master/BUILD.mingw64
ISSUE 1:
I first installed boost_1_51.zip but ran into problems compiling so
installed boost_1_46_1.zip as he suggested. I was able to bootstrap 1_51
and get a bjam.exe without a problem. But I could not get 1_46_1 to
bootstrap :(
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
c:\ming64\projects\boost_1_46_1>bootstrap.bat mingw
Building Boost.Jam build engine
'cl' is not recognized as an internal or external command,
operable program or batch file.
Failed to build Boost.Jam build engine.
Please consult bjam.log for furter diagnostics.
You can try to obtain a prebuilt binary from
http://sf.net/project/showfiles.php?group_id=7586&package_id=72941
Also, you can file an issue at http://svn.boost.org
Please attach bjam.log in that case.
So I built 1_46_1 using the bjam.exe that I built in 1_51 and it seems
to have worked ok, but maybe that is part of the problem.
ISSUE 2:
Is the follow mess from the linker
Scanning dependencies of target routing_dd
[ 80%] Building C object
core/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.c.obj
[ 86%] Building CXX object
core/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.cpp.obj
In file included from
c:/ming64/projects/pgx64/pg92/include/postgresql/server/pg_config_os.h:37:0,
from
c:/ming64/projects/pgx64/pg92/include/postgresql/server/c.h:87,
from
c:/ming64/projects/pgx64/pg92/include/postgresql/server/postgres.h:47,
from
c:/ming64/projects/pgrouting/core/driving_distance/src/alpha.h:27,
from
c:/ming64/projects/pgrouting/core/driving_distance/src/alpha_drivedist.cpp:46:
c:\ming64\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.5.4/../../../../x86_64-w64-mingw32/include/winsock2.h:13:2:
warning: #warning Please include winsock2.h before windows.h
[ 93%] Building CXX object
core/driving_distance/src/CMakeFiles/routing_dd.dir/boost_drivedist.cpp.obj
[100%] Building C object
core/driving_distance/src/CMakeFiles/routing_dd.dir/drivedist.c.obj
Linking CXX shared library ../../../lib/librouting_dd.dll
Creating library file: ../../../lib/librouting_dd.dll.a
c:/ming64/msys/local/lib/libboost_thread-mgw45-mt-1_46_1.a(thread.o):
duplicate section
`.data$_ZTVN5boost16exception_detail10clone_implINS0_19error_info_injectorISt9bad_allocEEEE[vtable
for
boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<std::bad_alloc>
>]' has different size
c:/ming64/msys/local/lib/libCGAL.a(all_files.cpp.obj):all_files.cpp:(.text+0xf898):
undefined reference to `boost::system::generic_category()'
c:/ming64/msys/local/lib/libCGAL.a(all_files.cpp.obj):all_files.cpp:(.text+0xf8a4):
c:/ming64/msys/local/lib/libCGAL.a(all_files.cpp.obj):all_files.cpp:(.text+0xf8b0):
undefined reference to `boost::system::system_category()'
collect2: ld returned 1 exit status
make[2]: *** [lib/librouting_dd.dll] Error 1
make[1]: *** [core/driving_distance/src/CMakeFiles/routing_dd.dir/all]
Error 2
make: *** [all] Error 2
More information about the pgrouting-dev
