[pgrouting-dev] [pgr_2.0] What is add_vertices_geometry(geom_table) use for?
Daniel Kastl daniel at georepublic.de
Thu Mar 21 17:09:59 PDT 2013
On Fri, Mar 22, 2013 at 4:49 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 3/21/2013 3:08 PM, Stephen Woodbridge wrote:
>> Hi all,
>> I am review the existing pgRouting SQL functions and in
>> routing_core_wrappers.sql we have a function:
>> add_vertices_geometry(geom_**table)
> Add to this:
>   update_cost_from_distance(**geom_table)
I would say: remove everything that is a) not documented and b) not used.
It's good to post it hear or make a list of removed functions in the
Wiki,so someone, who uses this, can say "stop" or we can reference the list
of removals in the release notes.
It could be that these functions came from pgDijkstra already, if they were
not added later.
Anyway, let's remove unused stuff that makes maintenance harder.
Daniel
>  I don't see it referenced anywhere so I assume this is some utility
>> function that somebody added for some purpose.
>> Any objections to removing this?
>> My goal here is the following:
>> 1. review and decruft existing SQL
>> 2. relocate functions into the folders that they belong to
>> 3. refactor the code and/or standardize function calling arguments
>> 4. add pgr_ prefixes to all the pgRouting functions
>> 5. add comments and documentation to the SQL
>> Thanks,
>>    -Steve
>> ______________________________**_________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130322/eb482c1e/attachment.html>
More information about the pgrouting-dev mailing list
