[pgrouting-dev] PostGIS 2.1, Postgresql 9.3 and pgRouting - We need a plan!
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 3 18:25:34 PDT 2013
Daniel, et al,
PostGIS 2.1 is hitting feature freeze to sync up with
PostgreSQL 9.3 which is going to Beta
And we need to be able to support PostGIS being able to package a
pgRouting on Windows with PostGIS 2.1. I already have pgrouting build in
the postgis build bot, so the focus should be on the code and sql fixes
as I outline below.
So I think we need a plan for this, and some people effort would be good
also.
It seems to me that we need someone to:
Setup an environment with pg 9.3 beta, postgis 2.1 trunk and take our
pgrouting master and make changes required to make it work in that
environment and package up a release.
This should not include any new features.
It should include ST_ fixes that we have a pull request for
It should include some of the bug fixes that we have pull requests for
It must include any additional compatibility changes.
It must include some basic testing (we can pull the tests from my 2.0
branch to make things simple)
This would be called version 1.06
This needs to happen after we move the branches around, which I hope to
get to on Sunday.
Anyone available to manage this release and tackle the items above?
Anyone able to fund this at any level?
Thoughts?
-Steve
More information about the pgrouting-dev mailing list
