[pgrouting-dev] Build
Daniel Kastl daniel at georepublic.de
Sun Nov 24 06:37:10 PST 2013
Just some additional comment:
I wanted to fill in the minimum required versions, but just didn't try
ancient versions of Boost and CGAL, or uncommon combinations.
In general pgRouting seems to work with recent version of Boost and CGAL,
or with versions that are available in package mangers of popular Linux
distributions.
So I don't know what to write instead of "[TBD]". Maybe we should just list
the dependencies and remove the minimum required version part, where we
don't know about it.
Daniel
On Sun, Nov 24, 2013 at 3:01 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 11/23/2013 10:21 PM, Stephen Mather wrote:
>> Do we know yet what the minimum versions are for building listed here?:
>> http://docs.pgrouting.org/2.0/en/doc/src/installation/build.html#build
>> e.g. what can I get away with for Boost... .
> I was running Boost 1.34 on a Lenny system without a problem until some
> other dependency caused builds to fail.
> I have built with 1.42 on squeeze and 1.49 on wheezy.
> In general, most versions will work. I think there was one maybe two
> versions that were broken because of some that boost did like moving
> includes around but I have since then ifdef's the boost versions if there
> is an issue that I know about.
> Too many to test them all! If you find one that does not work, file a bug
> and I'll fix it or document it as a problem.
> Thanks,
>   -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131124/b1281b96/attachment.html>
More information about the pgrouting-dev mailing list
