[pgrouting-dev] Build
Stephen Mather stephen at smathermather.com
Sun Nov 24 18:48:51 PST 2013
Is it wrong to set a minimum known version?  You could even specify it as
such.  It would give people an opportunity to decide if their package
managed versions stand a change before building from source.
Best,
Steve
On Sun, Nov 24, 2013 at 9:37 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Just some additional comment:
> I wanted to fill in the minimum required versions, but just didn't try
> ancient versions of Boost and CGAL, or uncommon combinations.
> In general pgRouting seems to work with recent version of Boost and CGAL,
> or with versions that are available in package mangers of popular Linux
> distributions.
> So I don't know what to write instead of "[TBD]". Maybe we should just
> list the dependencies and remove the minimum required version part, where
> we don't know about it.
> Daniel
> On Sun, Nov 24, 2013 at 3:01 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 11/23/2013 10:21 PM, Stephen Mather wrote:
>>> Do we know yet what the minimum versions are for building listed here?:
>>> http://docs.pgrouting.org/2.0/en/doc/src/installation/build.html#build
>>> e.g. what can I get away with for Boost... .
>> I was running Boost 1.34 on a Lenny system without a problem until some
>> other dependency caused builds to fail.
>> I have built with 1.42 on squeeze and 1.49 on wheezy.
>> In general, most versions will work. I think there was one maybe two
>> versions that were broken because of some that boost did like moving
>> includes around but I have since then ifdef's the boost versions if there
>> is an issue that I know about.
>> Too many to test them all! If you find one that does not work, file a bug
>> and I'll fix it or document it as a problem.
>> Thanks,
>>   -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131124/e0ccfdba/attachment.html>
More information about the pgrouting-dev mailing list
