[pgrouting-dev] GSoC Pencils down: 11 August - Last coding day: 18 August
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Aug 5 06:31:48 PDT 2014
Hi Guys,
The last two weeks of GSoC are rapidly approaching as you are aware.
Your priority at this point so to make sure your code can be called from
SQL and return its results to SQL. This should be your priority to
insure that this works ASAP, then you can go back to fine tuning your
algorithm.
Mukul, your code should be in pretty good shape but you should check and
verify that nothing has broken.
Mani, I know you are working on this. Ask questions if you get stuck,
time is short.
Thanks,
-Steve
More information about the pgrouting-dev
