[pgrouting-dev] GSoC Pencils down: 11 August - Last coding day: 18 August
Mukul priya
mukul2047 at gmail.com
Tue Aug 5 10:29:00 PDT 2014
I will prioritize the SQL querry and some documentation for now and then
come back to improvization.
On Tue, Aug 5, 2014 at 7:01 PM, Stephen Woodbridge <woodbri at swoodbridge.com>
wrote:
> Hi Guys,
> The last two weeks of GSoC are rapidly approaching as you are aware.
> Your priority at this point so to make sure your code can be called from
> SQL and return its results to SQL. This should be your priority to insure
> that this works ASAP, then you can go back to fine tuning your algorithm.
> Mukul, your code should be in pretty good shape but you should check and
> verify that nothing has broken.
> Mani, I know you are working on this. Ask questions if you get stuck, time
> is short.
> Thanks,
> -Steve
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140805/45ea2619/attachment.html>
More information about the pgrouting-dev
