[pgrouting-dev] RbRouting ruby wrapper for select pgRouting 2.0 functions
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 10 21:44:13 PDT 2014
On 3/11/2014 12:34 AM, Jordan Anderson wrote:
> Hey all,
> I'm working on a ruby wrapper for some pgRouting 2.0 functions that
> I'm calling RbRouting. This is based on some ruby code that I pulled
> out of ridethecity.com and made a bit more generic. Currently, I've
> defined classes to generate TRSP, Dijkstra, and A* shortest paths, as
> well as a method to run osm2pgrouting. (I haven't actually tested the
> restrict_sql part of TRSP yet, but in theory it should work!)
> My goal is to provide this plus a generic version of the logic
> ridethecity.com uses to generate its turn-by-turn directions, too,
> possibly via a separate class or plugin gem.
> Here's the repository: https://github.com/jordanderson/rb_routing
> I haven't published this to rubygems yet as it's still pretty rough
> around the edges and has no documentation, but I'd appreciate your
> feedback, issue reporting, or pull requests!
> Thanks,
> Jordan
Hi Jordan,
Thanks for your interest and your contribution.
I just added a new section to our wiki called "Friends of pgRouting"
https://github.com/pgRouting/pgrouting/wiki
and added a pointer to your project.
I don't use Ruby so I'm not much help there but I bet you will get some
others that are interested.
Best regards,
   -Steve
More information about the pgrouting-dev mailing list
