[pgrouting-dev] Some GSoC ideas about pgRouting
Maoguang Wang
xjtumg1007 at gmail.com
Fri Feb 24 09:01:29 PST 2017
I am not interested in developing an application using pgRouting. Instead,
I am exceedingly interested in pgRouting itself and algorithms. I have
coded many algorithms problems with C++ and Python, pgRouting and GSoC are
precious chances for me to get in touch with open source world.
Here are my ideas about pgRouting, I'm really appreciated with any advice
from yours :)
Ideas:
1> about C++ Boost graph algorithms, there are still some graph
algorithms not in pgRouting(planer graph algorithms, etc.)
2> about Vehicle Routing Problem: Pickup and Delivery, use
shortest path algorithms(Dijkstra, Dijkstra + Heap, Bellman Ford, SPFA,
etc.)
3> about Support for variable priorities (order, vehicle), maybe
use Astar algorithms is better.
4> about Chinese Postman Problem, it's an easy problem on undirect
graph.Otherwise, this problem is NP-Hard.Maybe heuristic algorithms(Astar
etc.) will be helpful.Use Kruskal algorithms(only consider vertices with
odd degree) to make MST and match these vertices, then we get approximate
solution with less time complexity.
Thanks,
Maoguang Wang
2017-02-24 22:32 GMT+08:00 Vicky Vergara <vicky at georepublic.de>:
> Hello Wang.
> From the last mail you sent, looks like you want to develop an application
> *using* pgRouting, for GSoC in the pgRouting project, we want people to
> develop *more functionality into* pgRouting. Maybe some other projects
> use pgRouting to develop their functionality.
> Please read carefully:
> https://github.com/pgRouting/pgrouting/wiki/GSoC-Ideas
> specially the section:
> https://github.com/pgRouting/pgrouting/wiki/GSoC-Ideas#for-
> gsoc-2017-we-require-applicants-to
> and communicate with us in gitter so we can have a conversation
> https://gitter.im/pgRouting/pgrouting
> regards
> Vicky
> On Fri, Feb 24, 2017 at 8:25 AM, Maoguang Wang <xjtumg1007 at gmail.com>
> wrote:
>> Hi, everyone,
>> I come again :)
>> I have been configuring the development environment(PostgreSQL+PostGIS+PgRouting)
>> last day. I have done this work on my MacBook today morning. Now I can use
>> functions in PgRouting to analyze map of Beijing :)
>> I used 'shp2pgsql' to convert shp file into sql file and imported it to
>> my database. And 'pgr_dijkstra' allowed me to run Shortest Path Algorithm
>> on my database. Finally I used 'pgsql2shp' to export results as shp file.
>> So that I can show them by Arcmap.
>> I have exceedingly interested in PgRouting(and other open source
>> libraries) and I will continue to read source code of PgRouting and learn
>> how to develop it. But I'm not sure whether learning more about PostgreSQL
>> and PostGIS would help. I wonder if you could give me some advices about
>> it. :)
>> Thanks,
>> Maoguang Wang
>> 2017-02-23 13:26 GMT+08:00 Daniel Kastl <daniel at georepublic.de>:
>>> Hi Maoguang,
>>> Thank you for introducing yourself!
>>> Still mentoring organizations for this year's GSoC have not been
>>> approved yet, but you can read through the pgRouting GSoC Wiki page:
>>> https://github.com/pgRouting/pgrouting/wiki/Google-Summer-of-Code
>>> Best regards,
>>> Daniel
>>> On Thu, Feb 23, 2017 at 1:55 PM, Maoguang Wang <xjtumg1007 at gmail.com>
>>> wrote:
>>>> Hi, everyone,
>>>> I am currently a second year student majoring in Information and
>>>> Computing Science.
>>>> I am familier with graph algorithms(I got ACM-ICPC 2016
>>>> China-Final Gold Medal last year) and would love to contribute to pgRouting
>>>> in GSoC this year.
>>>> _______________________________________________
>>>> pgrouting-dev mailing list
>>>> pgrouting-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: https://georepublic.info
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20170225/d3c98d51/attachment-0001.html>
More information about the pgrouting-dev
