[pgrouting-users] Adding bike routes to database
Daniel Kastl daniel.kastl at georepublic.de
Wed Aug 11 15:34:10 EDT 2010
Hi Yasir,
I have some bike routes data that I would like to insert to the 'ways' table
> in my pgrouting database.
> For routing using the added routes, do I need to run assign_vertex_id
> again?
If you can ensure that you keep a valid topology you don't have to run it
again. But probably it's easier to do so.
> Also, there are existing streets where the bike routes would be added,
> would this be any problem?
You might have a problem if nodes get very close to existing ones. they
might "snap" if you set your "tolerance" value too high.
Also I'm not sure you want to create new roads beside existing ones.
Probably you would like to try to match your bike routes with existing
roads.
Best regards,
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100812/045d886e/attachment.html
More information about the Pgrouting-users mailing list
