[pgrouting-users] TIGER/Line ZLevel
Daniel Kastl daniel at georepublic.de
Mon Feb 8 11:00:57 EST 2010
Has the OSM data been improved after Tiger data has been imported?
I can't say I know well about TIGER data as Stephen does, but since
OSM data contains Tiger data it might be an option, I thought.
Daniel
2010/2/9 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 2/7/2010 5:24 PM, John Hennessy wrote:
>> I am trying to use the TIGER/Line shapefiles for routing.  I have
>> managed to import the data and generate routes.  Unfortunately it
>> looks like this data set does not include ZLevel information so I am
>> getting routes that would have me drive off overpasses etc.  Anyone
>> have a solution to this?
> There is no solution to this problem that I'm aware of and I have worked
> extensively with the Tiger data over the last 10-12 years. The data does
> not exist in the Tiger data set, unfortunately. You will also note that
> one-way road information does not exist, so you are likely routing down
> the wrong side of dual lane digitized interstates also.
> -Steve W
>  http://imaptools.com/
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
More information about the Pgrouting-users mailing list
