[pgrouting-users] pgrouting installation
Ali Taha ali.taha at ritaj.ps
Mon Sep 12 13:20:57 EDT 2011
Dear All,
I am trying to setup and test pgrouting, I followed the setups but it is
still not working.  If ollowed the following steps:
1-      Copay pgrouting libraries to ..\pgsql\8.4\lib
2-      Execute routing_core.sql and routing_core_wrappers.sql
3-      Create a newtwork:
a.       Added source and target fields
b.      Execute Execute assign_vertex_id('<table>', float tolerance,
'<geometry column', '<gid>')
c.       Added indices
d.      Added reverse_cost column.
Then I used the following query to retrieve records:
SELECT * FROM shortest_path('
SELECT gid as id,
source::integer,
target::integer,
length::double precision as cost
FROM ways',
24154,
24157,
false, false)
the query executes without errors, but return no data. I checked the table
and the records seems OK.
is there a way to validate the database and verify the topology? How to make
sure that the pgrouting library (dlls) are installed and working correctly?
Thanks
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110912/bb83bf0f/attachment.html
More information about the Pgrouting-users mailing list
