[pgrouting-users] pgrouting installation
Daniel Kastl daniel at georepublic.de
Mon Sep 12 23:33:37 EDT 2011
On Mon, Sep 12, 2011 at 11:20 AM, Ali Taha <ali.taha at ritaj.ps> wrote:
> Dear All,****
> I am trying to setup and test pgrouting, I followed the setups but it is
> still not working.  If ollowed the following steps:****
> **1-      **Copay pgrouting libraries to ..\pgsql\8.4\lib
>From where did you copy them?
Did you compile? Which OS?
Daniel
> **2-      **Execute routing_core.sql and routing_core_wrappers.sql****
> **3-      **Create a newtwork:****
> **a.       **Added source and target fields****
> **b.      **Execute Execute assign_vertex_id('<table>', float tolerance,
> '<geometry column', '<gid>')****
> **c.       **Added indices ****
> **d.      **Added reverse_cost column.****
> Then I used the following query to retrieve records:****
> SELECT * FROM shortest_path(‘****
> SELECT gid as id,****
> source::integer,****
> target::integer,****
> length::double precision as cost****
> FROM ways’,****
> 24154,****
> 24157,****
> false, false)****
> the query executes without errors, but return no data. I checked the table
> and the records seems OK. ****
> is there a way to validate the database and verify the topology? How to
> make sure that the pgrouting library (dlls) are installed and working
> correctly?****
> Thanks****
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110912/5befb12a/attachment-0001.html
More information about the Pgrouting-users mailing list
