[pgrouting-users] Fwd: NiuRouting, PgRouting for SQLite
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Feb 21 14:53:49 EST 2012
On 2/21/2012 2:33 PM, Jaak Laineste wrote:
>> I am very happy to share with you a SQLite extension that allows
>> part of PgRouting routines, the project initially has a solution
>> toTRSP included in PgRouting, I hope to support the project.
>> https://github.com/jorgeliecer/NiuRouting
> This is very cool. Have you noticed that Spatialite has also basic
> Djikstra functionality for SQLite? I'm mostly interested in mobile
> environments but Spatialite solution requires too much memory for it.
> It loads whole graph to running memory, and if it is larger than
> about 10MB then it does not work in Android for example. pgRouting as
> such has similar approach. What about your implementation in this
> regards?
I think the trick here is to only load the topology for the bbox needed
to solve the query. This is what pgRouting does.
-Steve
More information about the Pgrouting-users
