[pgrouting-users] Shortest Path TRSP
Max Weninger
max.weninger at gmail.com
Mon Feb 27 16:55:22 EST 2012
Hi
The message "Source not Found" says that trsp
has not found the source node in the table reseau_global
Are you sure there is a node 15326?
Regards
max
On Mon, 27 Feb 2012 22:42:04 +0100
"Christophe Damour (SIGéal)" <sigeal at sigeal.com> wrote:
> Hi,
> I am trying to use trsp shortest path function, but get a "Source Not
> Found" error.
> Here is my query :
> SELECT edge_id FROM turn_restrict_shortest_path(
> 'SELECT id_tron as id, source::integer, target::integer,
> cost::double precision as cost, rev_cost::double precision
> as reverse_cost FROM reseau_global',
> 15326,
> 8756,
> true,
> true,
> 'SELECT to_cost::double precision, target_id::integer,
> via_path::text FROM reseau_global_rest'
> ), reseau_global
> WHERE edge_id = id_tron;
> reseau_global is my network table, and reseau_global_rest is my turn
> restriction table.
> In the latter, target_id column contains destination edges ids and
> via_path a list of forbidden origin edges.
> What am I doing wrong ?
> Thank for any hints,
More information about the Pgrouting-users
