[pgrouting-users] Shortest Path TRSP
Max Weninger max.weninger at gmail.com
Mon Feb 27 17:01:02 EST 2012
Hi again
Ok this is strange. Since the soure vertex is already
checked before the trsp is called. The message you
described comes directly from the C++ impl. of trsp
where it is checked again
Does the values of your source and target columns start from 0?
Since if this is not the case some "renumbering" is done internally
Maybe there is a bug.
Regards
max
On Mon, 27 Feb 2012 22:55:22 +0100
Max Weninger <max.weninger at gmail.com> wrote:
> Hi
> The message "Source not Found" says that trsp
> has not found the source node in the table reseau_global
> Are you sure there is a node 15326?
> Regards
> max
> On Mon, 27 Feb 2012 22:42:04 +0100
> "Christophe Damour (SIGéal)" <sigeal at sigeal.com> wrote:
> > Hi,
> > I am trying to use trsp shortest path function, but get a "Source
> > Not Found" error.
> > Here is my query :
> > SELECT edge_id  FROM turn_restrict_shortest_path(
> >      'SELECT id_tron as id, source::integer, target::integer,
> >          cost::double precision as cost, rev_cost::double precision
> > as reverse_cost FROM reseau_global',
> >      15326,
> >      8756,
> >      true,
> >      true,
> >      'SELECT to_cost::double precision, target_id::integer,
> > via_path::text FROM reseau_global_rest'
> > ), reseau_global
> > WHERE edge_id = id_tron;
> > reseau_global is my network table, and reseau_global_rest is my
> > turn restriction table.
> > In the latter, target_id column contains destination edges ids and
> > via_path a list of forbidden origin edges.
> > What am I doing wrong ?
> > Thank for any hints,
More information about the Pgrouting-users mailing list
