[pgrouting-users] Shortest Path TRSP
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Feb 27 17:07:11 EST 2012
If you think it is a bug, I'm happy to take a look at it, but ideally
you should try to reduce the problem to a small graph that is reproducable.
-Steve
On 2/27/2012 5:01 PM, Max Weninger wrote:
> Hi again
> Ok this is strange. Since the soure vertex is already
> checked before the trsp is called. The message you
> described comes directly from the C++ impl. of trsp
> where it is checked again
> Does the values of your source and target columns start from 0?
> Since if this is not the case some "renumbering" is done internally
> Maybe there is a bug.
> Regards
> max
> On Mon, 27 Feb 2012 22:55:22 +0100
> Max Weninger<max.weninger at gmail.com> wrote:
>> Hi
>> The message "Source not Found" says that trsp
>> has not found the source node in the table reseau_global
>> Are you sure there is a node 15326?
>> Regards
>> max
>> On Mon, 27 Feb 2012 22:42:04 +0100
>> "Christophe Damour (SIGéal)"<sigeal at sigeal.com> wrote:
>>> Hi,
>>> I am trying to use trsp shortest path function, but get a "Source
>>> Not Found" error.
>>> Here is my query :
>>> SELECT edge_id FROM turn_restrict_shortest_path(
>>> 'SELECT id_tron as id, source::integer, target::integer,
>>> cost::double precision as cost, rev_cost::double precision
>>> as reverse_cost FROM reseau_global',
>>> 15326,
>>> 8756,
>>> true,
>>> true,
>>> 'SELECT to_cost::double precision, target_id::integer,
>>> via_path::text FROM reseau_global_rest'
>>> ), reseau_global
>>> WHERE edge_id = id_tron;
>>> reseau_global is my network table, and reseau_global_rest is my
>>> turn restriction table.
>>> In the latter, target_id column contains destination edges ids and
>>> via_path a list of forbidden origin edges.
>>> What am I doing wrong ?
>>> Thank for any hints,
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
