[pgrouting-users] assign_vertex_id error
Dave Potts
dave.potts at pinan.co.uk
Tue Jun 12 07:51:15 PDT 2012
What happens if you say
select count(*) from xxxx_Table where the_geom is null;
where xxxx_Table is the name of the table and the_geom is the name of your
geomtry column ?
This statement should return the number of null columns, it should be zero.
Annu Anurag wrote:
> Sorry Steve sir. But I tried the DROP CONSTRAINT command like you wrote.
> But its not working. I got the same error.
> VSDelhidb=# SELECT assign_vertex_id('roads_line', 0.0002, 'the_geom',
> 'gid');
> NOTICE: CREATE TABLE will create implicit sequence "vertices_tmp_id_seq"
> for serial column "vertices_tmp.id"
> CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
> PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
> ERROR: new row for relation "vertices_tmp" violates check constraint
> "enforce_srid_the_geom"
> CONTEXT: SQL statement "INSERT INTO vertices_tmp(the_geom) VALUES
> (SetSRID(p,_srid))"
> PL/pgSQL function "point_to_id" line 26 at SQL statement
> PL/pgSQL function "assign_vertex_id" line 33 at assignment
> It says new row for relation "vertices_tmp" violates check constraint.
> Could it be that this constraint is derived or inherited from somewhere?
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
