[pgrouting-users] How to install pgRouting for Postgres 12 on Windows?
chintan pathak
chintan.pathak at gmail.com
Mon Oct 7 16:26:07 PDT 2019
Dear Regina,
Thanks a lot for adding the alpha and dev binaries. I copied the files from
extension and lib folders into the relevant folder in my Postgres 12
installation and was able to create the pgrouting extension. I checked the
version of the installed extension using `select pgr_version()` and it
showed 3.0.0 alpha and dev respectively. Let me know if I should run any
other specific checks to ensure proper installation. Otherwise, I will
continue using this and let you know if I run into any issues.
Thanks
On Mon, Oct 7, 2019 at 3:36 PM Regina Obe <lr at pcorp.us> wrote:
> Have pgrouting 3.0.0-alpha and dev packaged for PostgreSQL 12. Can you
> give those a try.
> https://winnie.postgis.net/download/windows/pg12/buildbot/
> Thanks,
> Regina
> *From:* Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Monday, October 7, 2019 4:46 PM
> *To:* 'pgRouting users mailing list' <pgrouting-users at lists.osgeo.org>
> *Subject:* RE: [pgrouting-users] How to install pgRouting for Postgres 12
> on Windows?
> Chintan,
> I should have the pgRouting binaries for pg12 available sometime this week
> and will definitely be available with the PostGIS 3.0 release. I was hoping
> to have pgRouting 3.0 in there as well.
> I’ll add to the repo in a bit so you will at least have the binaries.
> Thanks,
> Regina
> *From:* Pgrouting-users [mailto:pgrouting-users-bounces at lists.osgeo.org
> <pgrouting-users-bounces at lists.osgeo.org>] *On Behalf Of *Chintan Pathak
> *Sent:* Monday, October 7, 2019 2:36 PM
> *To:* pgrouting-users at lists.osgeo.org
> *Subject:* [pgrouting-users] How to install pgRouting for Postgres 12 on
> Windows?
> I am trying to use the Postgres 12 for my GIS workflow. I have been able
> to install PostGIS 3.0 beta with details below:
> POSTGIS="3.0.0beta1 r17835" [EXTENSION] PGSQL="120"
> GEOS="3.8.0-CAPI-1.12.0 " SFCGAL="1.3.2" PROJ="Rel. 5.2.0, September 15th,
> 2018" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3
> (Internal)" TOPOLOGY
> I found this from the experimental builds
> <https://winnie.postgis.net/download/windows> for PostGIS, which usually
> contains the pgRouting binary, but not for PG12. Has anyone successfully
> installed pgRouting with PG12? Any suggestions to build on Windows? I tried
> the official instructions for building on Windows in pgRouting
> <http://docs.pgrouting.org/dev/en/pgRouting-installation.html> docs,
> though I am getting stuck on the configuration.
> Thanks,
> Chintan Pathak
> Ph.D. Student,
> Sustainable Transporation Lab, University of Washington
> https://about.me/chintanpathak
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Chintan Pathak
[image: https://]about.me/chintanpathak
<https://about.me/chintanpathak?promo=email_sig&utm_source=email_sig&utm_medium=email_sig&utm_campaign=external_links>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20191007/e788a7e1/attachment-0001.html>
More information about the Pgrouting-users
