[pgrouting-users] How to install pgRouting for Postgres 12 on Windows?
Daniel Kastl daniel at georepublic.de
Mon Oct 7 18:03:24 PDT 2019
Thanks a lot, Regina!
Without you nobody could respond to Windows questions ;-)
And thanks for you offer to test, Chintan!
That's very much appreciated. If you find some issues, feel free to create
a ticket on Github.
Best regards,
Daniel
On Tue, Oct 8, 2019 at 8:26 AM chintan pathak <chintan.pathak at gmail.com>
wrote:
> Dear Regina,
> Thanks a lot for adding the alpha and dev binaries. I copied the files
> from extension and lib folders into the relevant folder in my Postgres 12
> installation and was able to create the pgrouting extension. I checked the
> version of the installed extension using `select pgr_version()` and it
> showed 3.0.0 alpha and dev respectively. Let me know if I should run any
> other specific checks to ensure proper installation. Otherwise, I will
> continue using this and let you know if I run into any issues.
> Thanks
> On Mon, Oct 7, 2019 at 3:36 PM Regina Obe <lr at pcorp.us> wrote:
>> Have pgrouting 3.0.0-alpha and dev packaged for PostgreSQL 12.  Can you
>> give those a try.
>> https://winnie.postgis.net/download/windows/pg12/buildbot/
>> Thanks,
>> Regina
>> *From:* Regina Obe [mailto:lr at pcorp.us]
>> *Sent:* Monday, October 7, 2019 4:46 PM
>> *To:* 'pgRouting users mailing list' <pgrouting-users at lists.osgeo.org>
>> *Subject:* RE: [pgrouting-users] How to install pgRouting for Postgres
>> 12 on Windows?
>> Chintan,
>> I should have the pgRouting binaries for pg12 available sometime this
>> week and will definitely be available with the PostGIS 3.0 release. I was
>> hoping to have pgRouting 3.0 in there as well.
>> I’ll add to the repo in a bit so you will at least have the binaries.
>> Thanks,
>> Regina
>> *From:* Pgrouting-users [mailto:pgrouting-users-bounces at lists.osgeo.org
>> <pgrouting-users-bounces at lists.osgeo.org>] *On Behalf Of *Chintan Pathak
>> *Sent:* Monday, October 7, 2019 2:36 PM
>> *To:* pgrouting-users at lists.osgeo.org
>> *Subject:* [pgrouting-users] How to install pgRouting for Postgres 12 on
>> Windows?
>> I am trying to use the Postgres 12 for my GIS workflow. I have been able
>> to install PostGIS 3.0 beta with details below:
>>     POSTGIS="3.0.0beta1 r17835" [EXTENSION] PGSQL="120"
>> GEOS="3.8.0-CAPI-1.12.0 " SFCGAL="1.3.2" PROJ="Rel. 5.2.0, September 15th,
>> 2018" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3
>> (Internal)" TOPOLOGY
>> I found this from the experimental builds
>> <https://winnie.postgis.net/download/windows> for PostGIS, which usually
>> contains the pgRouting binary, but not for PG12. Has anyone successfully
>> installed pgRouting with PG12? Any suggestions to build on Windows? I tried
>> the official instructions for building on Windows in pgRouting
>> <http://docs.pgrouting.org/dev/en/pgRouting-installation.html> docs,
>> though I am getting stuck on the configuration.
>> Thanks,
>> Chintan Pathak
>> Ph.D. Student,
>> Sustainable Transporation Lab, University of Washington
>> https://about.me/chintanpathak
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Chintan Pathak
> [image: https://]about.me/chintanpathak
> <https://about.me/chintanpathak?promo=email_sig&utm_source=email_sig&utm_medium=email_sig&utm_campaign=external_links>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20191008/ec9bf1fb/attachment.html>
More information about the Pgrouting-users mailing list
