[postgis-devel] autoconf paths
strk at refractions.net
Fri Apr 15 13:14:17 PDT 2005
On Fri, Apr 15, 2005 at 10:10:57PM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net schrieb:
> >I'm not sure we should keep relying on pgsql layout, although
> >your solution is viable. Actually I was thinking that allowing
> >storage of extension lib itself in a postgis-specific directory
> >would permit using different postgis versions for different
> >databases of the same cluster (does it make any sense?).
> Yes, it does make sense, it is what I do on my developer machines all
> day. :-)
> Sometimes, it is not possible to migrate one database to a new postgis
> version because the app is incompatible, but another app that uses a
> different database relies on the new features.
> So I think the most flexible may be to use the output of "pg_config
> --configure" by default, but allow both overriding individual parameters
> via --docdir, --bindir etc. or using --prefix to have everything bundled
> together in $PREFIX/bin, $PREFIX/lib etc. However, I think this may make
> the configuring process too complex.
No I think it's fine, no options for a default build, a --prefix for
a full-contained postgis installation. Any more complex setup would
require more complex ./configure call...
--strk;
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
